#1 Posted : Tuesday, 1 February 2005 8:09:28 PM(UTC)
Hi all,
I'm having some tuning trouble with the 202 in my LH Torana. It is a fairly new engine (5000 since rebuild), but with the original single throat stromberg carby, and an electronic dizzy setup from a VH commodore.
It runs on Shell Optimax, as it now has hardened valve seats and boosted compression. Built by someone who knows what they're doing.
I have set it up and tuned it to run beautifully (8 degrees, nice idle, etc).
Every so often, it will turn into a dog, won't idle (dies), always starts again, but runs rough, needs throttle, and pings very badly. Sometimes this is after engine breaking down a hill backfiring and farting badly. Some choke will help it from dying as often...
If I persist like this (I was towing last night, had no choice), after ten minutes of driving, and lots of red light stalls, it'll just come good again.
Then next time I drive it, it might play up again. It's like having two completely different cars...
My initial suspicion is either the carby has some rubbish in it (carby rebuilt 7 years ago, spent 1 year off the car in a plastic bag during the rebuild), or the dizzy is playing up and the advance is getting stuck??
I'm hesitant to touch the carby myself unless people here convince me otherwise.
Other than that I'll be putting it in to have the dizzy overhauled and regraphed.
I'm in western suburbs of Brisbane - any suggestions on a tuning expert?
Any words of advice? Apologies for the novel... figured it was no use posting without sufficient information.
Jason.
#2 Posted : Tuesday, 1 February 2005 9:14:46 PM(UTC)
The electronic ignition modules have a heat sink (silicone I think) that dries out over time and may stuffup the spark quality when hot. I would be looking at the dizzy first, the carby should have the problem all the time, not come and go like that. Of
#3 Posted : Tuesday, 1 February 2005 10:09:44 PM(UTC)
Thanks Peter, I hadn't considered air leak problems... will check this out tonight. It may just be time for a re-tension.
As for the dizzy, the heat sink would be internal?
Jason.
#4 Posted : Tuesday, 1 February 2005 11:44:47 PM(UTC)
bay, check the air lines to the brake boosta and tranny. My one had a leak at the tranny and jagged in wheneva it liked, sputtered and farted during idle and the choke kept it going, mayb a 2 person job if you have to get underneath - cheers 2 the mrs.
#5 Posted : Tuesday, 1 February 2005 11:54:43 PM(UTC)
The heat sink is under that 'block' that sticks out the side of the electronic dizzy. Apparently you can get the stuff and reapply it yourself, but I have never tried this.
Peter
#6 Posted : Wednesday, 2 February 2005 11:12:21 AM(UTC)
The module on the dissy is dead easy to do. go to repco or someone and buy some heat sink grease.
Take out the two screws on the sort of rectangular box on the side of the dissy, carefully lift the module (the thing with the wires going to it) underneath
