will the HK T G brake booster fit LC LJ torana? |
Havent you learnt anything from that guy that gives sermons at church?...Captain whats his name. |
The booster off an early HK will fit the LC/LJ booster bracket. These use a relay lever set-up similar to the Torana. This is how the XU-1 booster was built. There are minor internal valving differences, but it looks exactly the same as the XU-1 unit. The m/cyl pushrods differ, so make sure you get the correct m/cyl.
The late HK as well as HT & HG have a input pushrod which is way too long.
Dr Terry. |
