tranx Offline
#1 Posted : Monday, 8 June 2009 9:51:30 AM(UTC)
tranx
Is there a difference in the HK - G wiper motors?
I have taken off my HG van a wiper motor that has a long housing, then off a HT Kingswood a similar wiper motor but with the plastic Trico washer pump housing, and then off a HK station wagon another wiper motor but with a shorter housing.
Did Holden change the speeds or manufacturers from HK to HT in the wiper motors? If I knew how to post pix, I could explain what I mean.
Premier 350 Offline
#2 Posted : Monday, 8 June 2009 6:21:15 PM(UTC)
Premier 350
I have recollection of being told that the some HT-HG Belmonts used a washer motor under the washer tank, while the rest of the range used
that crappy pump attached to the wiper motor.
Could that be it? One of the gurus should be able to enlighten us.
Why are race officals so afraid of penalising 888 racing?
