HQforme Offline
#1 Posted : Wednesday, 10 June 2009 4:59:52 AM(UTC)
HQforme
I have one noisey lifter that i cant shake. It's definitely a lifter because it bleeds down overnight, starts off shockingly then pumps up to a light tap. Only one. I've reset preload three times to be sure, had three different people on the stethoscope, can't find it. So i'm thinking new lifters. I'm thinking that pulling, cleaning and inspecting the old ones is an average option as new lifters are a fairly economical purchase.
The cam is less than 6months old, but gets driven a few kays each day, to and from work (after a proper break in when i first got it).
There are two conflicting sides when it comes to putting new lifters on "old" cams. NEVER do it, or do it all the time, just give them a light scuff and repeat break in.
Thoughts?
"Silly modern cars"
Custom Offline
#2 Posted : Wednesday, 10 June 2009 6:25:54 AM(UTC)
Custom
Lifters are only about 6 and half $$$ each, theyre not expensive.
They will be fine on an old cam.
The other option is to just rev it harder and drown the noise out.
HQforme Offline
#3 Posted : Wednesday, 10 June 2009 7:58:11 AM(UTC)
HQforme
Oh, dont worry mate, thats what i do most of the time. Haha.
Ive got some new jets to throw in, so ill grab some lifters for the next working bee on the weekend. Cheers.
"Silly modern cars"
tanart Offline
#4 Posted : Wednesday, 10 June 2009 8:13:19 PM(UTC)
tanart
You can replace the lifter. Plenty of moly grease and run it in as if your running in your cam. About 2500 revs for about 10-15 min. Or if the lifter is not externally or internally damaged, just replace the guts of the lifter with the guts of a new lifter. Make sure you bleed the lifter before putting it back in. This way you wont wear out your cam.
HQforme Offline
#5 Posted : Thursday, 11 June 2009 4:01:59 AM(UTC)
HQforme
Cheers. If i can find which lifter is dodgy then i can strip/inspect or replace parts so that the body remains. But ive been told not to bleed these lifters when installing them new? Just good assembly lube and of course, crank the motor for oil pressure.
"Silly modern cars"
Sandman Offline
#6 Posted : Tuesday, 16 June 2009 5:01:33 AM(UTC)
Sandman
If you use moly lube change the oil and filter after the cams run in.
Moly can block an oil filter.
The Yeti Offline
#7 Posted : Wednesday, 17 June 2009 3:02:30 AM(UTC)
The Yeti
Ive done it several times usualy on old cross flow 6 fords as above with moly greese and as sandman sugests drop the oil and filter when your done
Ive had about a 95% sucess rate doign this
Macquarie Towns Hot Rod Clubs new website http://www.hotrodclub.info
See The Yetis Chev build at
http://www.ozrodders.com...rd/viewtopic.php?t=17919
See The Yeti's Chev build at
