Can anyone tell me exactly (photos, measurements etc)where these chassis bracing bars fit. do they pick up existing holes or do I need to drill some. thanks
The holes will be there on HZ and WB that had them. See if you can find a WB Statesman and look. Holes are on the engine crossmember and on the chassis adjacent to the body bolts under your feet (one on drivers side and one on passengers side). Bars are left and right handed too. If you dont have them yet just get them and the bolts off a WB Statesman. As a side note, I have a late HX tonner chassis and it has the holes too. They might be there on all chassis with RTS suspension geometry.
I believe they were standard on commercials and V8s in the HZ model but all HZ subframes had the holes for them. I took a pair off an HZ ute I wrecked and put them on my HJ Coupe which has an HZ wagon subframe under it and the mounting holes were there.
Cheers, Pete. Old Holdens never die, they just go faster. |
part of out back pack from hq on to wb and fitted to all melbourne cabs ex factory from late 1975 and retro fitted to all existing melb cabs in hq and early hj in 1975
looking for an ex ambulance based on the hj/x/z 2 tonner see photo
and collector of all things ambulance police fire and the odd hq to wb parts |
