Anthony333 Offline
#1 Posted : Thursday, 18 June 2009 6:16:33 AM(UTC)
Anthony333
Hi all...
I have a Turbo 400 that i have previously drained and put in a new filter / gasket seals etc... i cant remember exactly how much fluid came out , and i want to refill it ... the converter was not drained..
As far as i know it takes about 11 litres with converter..
I have put in about 3 litres, and as its out of the vehicle, i cant pump it up and circulate the fluid... so, how much fluid would have stayed in the trans ?
I drained it by removing the sump and draining ...
Thanks in advance, Ant
#2 Posted : Thursday, 18 June 2009 6:35:16 AM(UTC)
refill is only about 3 litres if you have only changed filter and drained it
