laurence Offline
#1 Posted : Thursday, 25 June 2009 3:57:43 AM(UTC)
laurence
Need to find Shop/supplier of Adapter M12 to 1/8 MPT so I can fit temp sender into LS2 head has someone done this or know were to get? Local shop has none and cannot help Talking rear of R/H head Thanks
klompy Offline
#2 Posted : Thursday, 25 June 2009 4:50:45 AM(UTC)
klompy
Hi I would just get a M12 plug and get it drilled and tapped to 1/8 MPT.Good luck.
80569K Offline
#3 Posted : Thursday, 25 June 2009 5:57:32 AM(UTC)
80569K
I have previously got this sort of stuff from engineering supplies shops, nut & bolt etc specialists, try the yellow pages. If you live in the Illawarra try GRQ at Warilla, maybe phone them they might put you onto someone in your area.
#4 Posted : Thursday, 25 June 2009 7:40:23 AM(UTC)
klompys idea is the best solution, get a 12mm plug or fitting of some type & tap it out to suit the temp sender..
BTW, the thread size is 1/8" NPT. It is the acronym for National Pipe Thread.
Dr Terry.
This page was generated in 0.080 seconds.
