kanks Offline
#1 Posted : Friday, 17 July 2009 11:35:31 PM(UTC)
kanks
hi does anyone think it would be possible to modify a set of headers from pre pollution to vn efi .as i can get a new set for my hg new for 250$ without plate welded on i was hopeing to buy vn plates and giveing this a go myself.thanks
#2 Posted : Saturday, 18 July 2009 1:18:47 AM(UTC)
if you are talking about trying to modify a pair of 253/308 headers to fit on VN heads then you have virtually zero chance as the 253/308 has the middle pipes in tandem whereas the VN heads have all four pipes evenly spaced.
You could *possibly* weld VN plates to a set of headers designed for a Ford engine as they have evenly spaced pipes.
If at first you dont succeed then skydiving is not for you.
