Evil Homer Offline
#1 Posted : Monday, 27 July 2009 6:53:21 AM(UTC)
Evil Homer
hi
am just putting together an hq ute everything is working fine except the indicators, have 12.5 volts to the flasher. have also replaced the flasher just in case it was faulty checked the new flasher in my hz wagon good as. STILL NO INDICATORS.
HQforme Offline
#2 Posted : Monday, 27 July 2009 8:17:43 AM(UTC)
HQforme
Ok, so you have power at the flasher, new flasher, what about power at the unit? Actually, my first thought would be to check the earth. They earth through the indicator body and its easily corroded. I hardwired my indicators for this reason in both of my HQs.
"Silly modern cars"
#3 Posted : Tuesday, 28 July 2009 5:03:37 AM(UTC)
check your earths, its most likely a earthing problem
Natmeisterus Offline
#4 Posted : Wednesday, 29 July 2009 8:14:22 AM(UTC)
Natmeisterus
same thing happened to me when i was putting that plastic tubing over my headlight/blinker wires to hide them, i forgot to reconnect the earth to the body
This page was generated in 0.099 seconds.
