hey yall, i has a no blinkers!! backed into something and wiped out my r side blinker,,?? then found i had no blinkers at all?? have checked every fuse and all seems well,?? so wondering whether blinker can is cactus? and would this cause none of them to work.?? what do blinker cans looky like?/ are they about 50mm round,,50mm high?? your input incredibly appreciated? cheers bcb
it was but yesterday, i thought myself a fragment, quivering without rythum in the sphere of life. now i know i am the sphere, and all of life quivers in rythmic fragments, within me! kg. |
more than basketcase than a bear! DOH!!! |
Joined: 25/11/2008(UTC) Views messages in topic : 1,496
your right blinker cans are usally about 50mm round 50mm high
have you replaced the globe yet? bad earth is the most cammon cause for non working blinkers, is the globe the same wattage as the rest of the globes?
thanks daveyq finally found plastic blinker can in fuse box! black plastic relay looking thing, am getting holden replacement one today, hopefully that will fixeeupperer ze blinker problemo! thanks bcb
