bronsonHX Offline
#1 Posted : Thursday, 30 July 2009 4:54:14 AM(UTC)
bronsonHX
gday, my guage is progressively getting worse and worse. 6 months ago it would show 3/4 when full, now it shows just over half. how do i fix this? it is probably the sender unit im guessing.
gts308 Offline
#2 Posted : Thursday, 30 July 2009 9:47:24 AM(UTC)
gts308
Easiest way to check would be to get someone to earth out the wire to your sender and see if the guage goes all the way to full.
Your float in the tank may have a small hole in it and its taking on fuel making it sink. Or its just a faulty sender.
"We are but a grain of sand on the beach of life"
jabba Offline
#3 Posted : Thursday, 30 July 2009 9:03:55 PM(UTC)
jabba
The other test is whether your fuel tank is properly earthed. Scrape some some of the gunge off the tank and a bit of nearby chassis and get someone to earth across properly. See if the gauge accuracy improves.
j
bronsonHX Offline
#4 Posted : Tuesday, 4 August 2009 5:06:15 AM(UTC)
bronsonHX
ok thanks, ill try earthing it better this weekend. gts308, if my float has a hole how do i fix that?
gts308 Offline
#5 Posted : Tuesday, 4 August 2009 10:23:00 AM(UTC)
gts308
The hole would be that small I doubt you would see it.
The float is part of the sender unit so if your going to pull the unit out you might as well just replace it with a new or good second hand unit.
Ute Version
Edited by user Tuesday, 4 August 2009 10:24:23 AM(UTC)  | Reason: Not specified
