kanks Offline
#1 Posted : Friday, 31 July 2009 9:55:42 PM(UTC)
kanks
has anyone done this conversion before i dont no weather to go v6 conversion one or castle autos one the first is cheaper but will be doing all work myself so it needs to be pretty simple thanks
#2 Posted : Saturday, 1 August 2009 8:34:47 AM(UTC)
If its like any of the others from the one with a name that is alluding to a place where kings & queens live, then they are junk.
Its not hard to make your own loom, and a good sparky would only be a few hundred to mod a loom to suit you.
I do EFI V8 ones for mates with early commodores & feel guilty charging them $150. I leave the engine loom exactly as it came from Holden, and make a loom to suit using bits from a VN V6 (fuel pump relay, fan relay, EFI relay, fusible links) and then patch it to the correct firewall plug to be a true plug & play to the recipient vehicle.
Its not quite that simple - you need to run fuel pump wiring, a speed sensor (do the www.v6conversions.com cable) and wires from the LH footwel plug across to the dash, but its not rocket science.
kanks Offline
#3 Posted : Saturday, 1 August 2009 7:06:49 PM(UTC)
kanks
thanks mick i work with 12 so called elecs and enginers will speak to them thanks for the reply
