#1 Posted : Wednesday, 16 February 2005 7:44:03 AM(UTC)
i have a HR with 202 and it gets hot a idle it has a xu1 cam and a 350 holly and a standard steel fan i hav put a new 3 core radiator in it but that hasnt fixed the problem when it is moving its fine only at idle i have the problem can anyone help me
#2 Posted : Thursday, 17 February 2005 7:05:58 AM(UTC)
It could be a number of things, did you have the engine flushed when the new radiator was fitted? But my guess would be the fan, does it have a fan shroud? If its the old 4 blade steel fan sitting in the open its probably not drawing enough air through ay
#3 Posted : Thursday, 17 February 2005 7:55:03 AM(UTC)
I would check the thermostat. If you have removed it, put it back in or it could be stuck open. If the water is flowing around the motor too quickly it does not cool when passing through the radiator.
It needs a restriction too slow the flow a bit.
