rb30EJvan Offline
#1 Posted : Sunday, 9 August 2009 1:46:53 AM(UTC)
rb30EJvan
i want to modify my original fuel tank cause i realy dont want to use a fuel cell. has anyone done this? do i only need to plum in a return line. i already have a swirl pot and external lift pump
edelbrock1 Offline
#2 Posted : Sunday, 9 August 2009 7:51:24 AM(UTC)
edelbrock1
I did a similar thing in a HK. I had a external lift pump to suck the fuel out of the tank via the original fuel line. Then into the swirl pot. Then to a high pressure pump to the motor and back to the swirl pot. Any over flow I routed into the fuel filler spout. Just tig welded the hose fitting into a hole I drilled in the pipe. Whole system works a treat and I did not have to root up a good tank. If I ever want to go back to original, I only have to replace the fuel filler pipe.
Hope this helps.
Edited by user Sunday, 9 August 2009 7:54:07 AM(UTC)  | Reason: Not specified
rb30EJvan Offline
#3 Posted : Sunday, 9 August 2009 9:33:14 AM(UTC)
rb30EJvan
cheers that sounds like a good idea and easy fix
thanks
