vanman Offline
#1 Posted : Monday, 10 August 2009 1:34:04 AM(UTC)
vanman
My sandman is dated 10mth 1975 I want to fit the correct engine so the numbers match.
I believe that having an engine block dated 4mths earlier than the vehicles build date is fine..(please advise if this is not the case).
But does anyone know how close can the build date of the block be to that of the vehicle ?
I only ask this as there is a 308 on eb@y dated 19j5 (19 nov 1975) and i was unsure if this is too late for my Van?
Vanman
anonymous Offline
#2 Posted : Monday, 10 August 2009 2:03:25 AM(UTC)
anonymous
The block has to be casted before the build date by about 4 to 2 weeks
so it depends what part of the 10th month the sandman was built.
19j5 is 19th Sept ( 9th month )1975 so it could fit in the time frame for a 10th month build dated sandman.
#3 Posted : Monday, 10 August 2009 2:45:13 AM(UTC)
that block would suit fine, being about 4 weeks prior to your van, anonymous is correct with the date thing too
(i) isnt used in the date codes, it is skipped to avoid confusion with 1
Edited by user Monday, 10 August 2009 2:46:55 AM(UTC)  | Reason: Not specified
vanman Offline
#4 Posted : Tuesday, 11 August 2009 6:28:50 AM(UTC)
vanman
this is the engine number i cant read the first two digits - rang the seller and he said he cant either.. so i dont know if the date refers to 1975 or 1985..
69HT_MUNRO Offline
#5 Posted : Tuesday, 11 August 2009 6:32:58 AM(UTC)
69HT_MUNRO
Hey Vanman
I think I met you yeserday at the cobram swapmeet.
We were talking to peter from moyhu?? Really good bloke to deal with.
Stephen
Be careful about reading health books. You may die of a misprint.
[email protected]
http://gallery.oldholden.com/69HT_MUNRO/
[email protected]
#6 Posted : Tuesday, 11 August 2009 6:56:54 AM(UTC)
if it was a 75 the engine would be red, 85 it would be blue or black
Edited by user Tuesday, 11 August 2009 7:04:36 AM(UTC)  | Reason: Not specified
vanman Offline
#7 Posted : Tuesday, 11 August 2009 7:39:48 AM(UTC)
vanman
69HT_MUNRO Yep mate thats me...I will hopefully drop round and see peter later on this week...
davequey74 Posted - 10/08/2009 : 8:56:54 PM if it was a 75 the engine would be red, 85 it would be blue or black
I understand the colours but what happens if it has been blasted or acid dipped and painted sometime over the last 30 odd years.. I think I need to know the first two letters to confirm
JBM Offline
#8 Posted : Thursday, 13 August 2009 12:42:12 AM(UTC)
JBM
If the block is a 75 with trimatic pattern on the back the web below the dowel will be narrow, if its an 85 this web will be much wider to fit the turbo dowel.
James
#9 Posted : Thursday, 13 August 2009 3:44:35 AM(UTC)
Vanman
Just a few quick comments.
In reality, 4 months earlier in the cast date is a fair amount of difference but is quite possible. Somewhere between 4 days and 4 weeks would be better but much bigger gaps could happen. As the engine isnt original to your van Id try for as close as possible beforehand. HOWEVER, the difference can also be plant dependant, and the actual engine number can vary widely across plants and differ by many months for consecutive numbers. If you ever get a chance to look at pages from original maintenance or build records and look closely at engine number trends you can see how much variation there is, plus how engine numbers close to each other can be installed in different plants months apart. So in short unless you know your original engine number you cannot even get close to making it "match" with another engine. Therefore you might as well use any engine of the same capacity as the original, if you get one close to the previous few weeks in casting date to your build date even better. In my opinion casting date is even less important as an engine number close to your original as the only "matching" numbers combination is the original. Remember though that QT650000 might be original to your van but QT650001 might have been put into a vehicle in another plant 2-3 months earlier or later (most likely itd be not QT but QL650001 or something other than QT).
And James, all HJ onwards blocks have the thicker rear casting, not just TH blocks.
#10 Posted : Friday, 14 August 2009 2:23:40 AM(UTC)
Byron is right,its only matching numbers with ONE engine,the rest are just time period.The good news is,it opens up a bigger pick/play field for one that you put in.Time period choices are the best option(except matching numbers)to go for,if originality is your thing.
Jim in adelaide
Guest (10)
This page was generated in 0.065 seconds.
