barber Offline
#1 Posted : Monday, 10 August 2009 6:49:16 AM(UTC)
barber
how much would it rufly cost to get a vn v6 block bored and polished if i have already got the engine out and striped its just a bare block no crank cam or pistons or bearings i need a price please even if its a estimate
[SORARE]
[SUPDUP]
[SORARE]
[SUPDUP]
#2 Posted : Monday, 10 August 2009 8:30:09 AM(UTC)
A bore & hone could be anywhere from $150 to $350 depending on where you go, how much else they do at the same time, and how bad the block is.
bundybluedog Offline
#3 Posted : Monday, 10 August 2009 6:47:24 PM(UTC)
bundybluedog
you will want to give your machinist the pistons you are useing as a good one will machine each bore to each cylinder as tolerances may very. you will also need it to be chemicaly cleaned which is about $100-$150 for both heads and block. you can add assembly costs if he needs to assemble to machine deck height.
interceptor Offline
#4 Posted : Thursday, 14 January 2010 8:13:04 AM(UTC)
interceptor
can you get the rings in a VT Commy bored out ??
#5 Posted : Thursday, 14 January 2010 10:55:01 AM(UTC)
OK, Im scratching my head with that one....
Boring refers to machining the cylinder bore back to an accurate circular shape, or correcting the alignment of the crank main bearing tunnel by boring it with the caps on (line boring).
What exactly do you want to do to the rings in a VT?
Utility8 Offline
#6 Posted : Thursday, 14 January 2010 7:25:55 PM(UTC)
Utility8
Ring an engine machine shop/builder & ask them. Thats what they do.
Utility8
utility8
