HQforme Offline
#1 Posted : Friday, 14 August 2009 1:18:35 AM(UTC)
HQforme
Ive just scored myself a nice YT head. It's a high comp head with big valves. They're been de-shrouded around the edges of the chamber. I know it's common practice to notch the block correspondingly, but as i plan to put this head on my bottom end (rebuilt, 40thou over, standard comp pistons) will there be any adverse effects of not having the notches, or will it mean i just don't get full advantage of the work done to the head?
Oh, and since this head uses adjustable rockers, so the pushrods are guided by the head, will i need different pushrods, hardened ones, as opposed to stock 202 units that ran with fixed rockers?
Kind regards,
Peter
Edited by user Friday, 14 August 2009 2:04:14 AM(UTC)  | Reason: Not specified
"Silly modern cars"
#2 Posted : Friday, 14 August 2009 2:12:52 AM(UTC)
I dont know about the notching?(or dont fully understand i suppose)but as for pushrods,get hardened ones if you can,because of the force nature of adjustable rockers, I think its best.(jmo)
Jim in adelaide
Grue Pugg Offline
#3 Posted : Friday, 14 August 2009 2:52:41 AM(UTC)
Grue Pugg
the notches are to ensure your valves dont collide with the deck as they open. check the clearance with clay, its a simple process to cut the notches with a die grinder. use head gasket as template and cut at 45-60 degrees
HQforme Offline
#4 Posted : Friday, 14 August 2009 4:54:25 AM(UTC)
HQforme
Cool. I wont attack the block while its still assembled so i guess ill rip the thing apart. Probably going to put my cam timing back to standard anyway. Cheers.
"Silly modern cars"
