billy has Offline
#1 Posted : Sunday, 16 August 2009 6:07:36 AM(UTC)
billy has
Hi,
Was directed to this site and specifically to a one Commodorenut.
So if anyone can help please do.
Model: VH8VX69-382
Body: 778933M
Trim: 4004-79Y
Paint: 2J011-D
Top: 2F010-B
L31--M40--GU4
Also, how do I know if engine is original?
I thought the blocks were painted blue yet this one is painted red.
Engine number: VT285628
Any help and info would be appreciated,thanks.
#2 Posted : Sunday, 16 August 2009 7:44:01 AM(UTC)
The body number confirms it as a genuine SL/E.
Its also an original 5L auto, with a 3.08:1 diff (most 5L were 2.6 diffs).
The trim combo code shows its a factory shadowtone Venetian Red Metallic over Mercury Silver Metallic. Interior trim is Dark Claret velour.
As far as checking if the engine is original, the only real way is to source the first rego records (unlikely) or the original owners manual.
You can also work out the casting number & check it against the cars build date - but by VH commodore, these can range from as little as the same month as the build, up to some 6 months prior to the compliance date of the car (proven by owners manuals).
If you dont have any paperwork detailing the engine number from new, then you can predict a range of engine numbers that are likely to belong to a particular month/year car - but its only a prediction, and even if the number does fall within that range, its still no guarantee its original.
Based on your body number, it should be a very late Nov, or very early Dec 81, and should have a chassis number around AVH014xxxM or AVH015xxxM.
If this is the case, then that engine number fits in well with that era, and is likely to be around the right time. Why its painted red I have no idea, but a lot can happen in 28 years.
Can I ask who/how you were referred to this site?
billy has Offline
#3 Posted : Sunday, 16 August 2009 8:14:08 AM(UTC)
billy has
Thank you very much Commodorenut!
Very much appreciated.
I was directed to you by a bunch of Aussie V8 forum members.
Commodorenut sounded serious so I tried here and lo and behold, Commodorenut has appeared!
Can I ring Holden and ask them about the engine?
#4 Posted : Sunday, 16 August 2009 10:53:24 PM(UTC)
Unfortunately Holden wont be able to help you, as they didnt retain those sorts of records in a retrievable format for the early commodores. Youll only have luck with that from around VN onwards.
