davidb9 Offline
#1 Posted : Saturday, 29 August 2009 8:52:44 PM(UTC)
davidb9
i have to change my crank angle sensor on my vt calais have go the front blot off but still having trouble get the harmonic balancer off have tired puller and it still wont budge can someone help me please
david
bundybluedog Offline
#2 Posted : Saturday, 29 August 2009 9:16:12 PM(UTC)
bundybluedog
Put ya pulla back on with a fiar bita pressure and use a hammer or a drift and hammer to tap around were the crank fits. Give it a few good clouts and if that dont help try a bit of inox and let is sit for a bit and have another go. If still no luck you may need to use a bit of heat(oxy) but direct it on the balancer only as you have a rubber seal behind it and rubber around the Blanacer.
