nhawtin Offline
#1 Posted : Friday, 18 September 2009 8:26:30 AM(UTC)
nhawtin
Have a mechnic (diff guy ) doin my diff up. have one problem it has about 100 thou of thrust movement.. pinion set up pot on , lash ok but it has his fault. new bearings the lot. any ideas before we scrap the whole thing and go nine inch please help
#2 Posted : Friday, 18 September 2009 7:24:02 PM(UTC)
What gears have you used? You have to use a spacer behind the crownwheel with some gearsets on a Chev 10 bolt. Remember how HQ-WB 10-bolt uses a different hemisphere for 2.6 and 2.78 compared to 3.08 and lower? In a Chev 10-bolt its a spacer for lower ratios (lower than 3.36). I also think you can buy aftermarket hemispheres to allow you to use the lower aftermarket gearsets without a spacer so maybe this could be your problem too?
#3 Posted : Friday, 18 September 2009 8:56:29 PM(UTC)
maybe get a new mechanic...
"We wreck = KNOWLEDGE" lolololol
petaus Offline
#4 Posted : Saturday, 19 September 2009 7:20:23 AM(UTC)
petaus
well something must of been changed, the two carrier bearings shims are not the same, were they put back in the same spot? these are changed to adjust backlash i.e one might be 183 thou the other 196thou even arseing this up would not give you that much backlash is it the original carrier, gear set and housing????
as hk said some have spacers.
like a early explorer go back retrace your steps look at what is new,you will find the problem.
the machines that make the falcon and commodre diff are going to china from what i hear, i cant wait for the first few batches of diffs to arrive lol a gearset is as only as good a the person on the lapping machine.
pete.
ozchevy Offline
#5 Posted : Saturday, 19 September 2009 8:08:04 AM(UTC)
ozchevy
Pete, I think you would find with todays technology, all gears are CNC Machined to the closest of tolerances and do not require any lapping compound of any nature near them.
Times have changed, they spit thousands out in a day, all within 000.1 of each other.
petaus Offline
#6 Posted : Sunday, 20 September 2009 6:27:21 AM(UTC)
petaus
far as i know even today they are still lapped...
