fitzsi Offline
#1 Posted : Sunday, 20 September 2009 3:11:47 AM(UTC)
fitzsi
Hi
Apart from the existing oil pressure sensor connection point at the oil pump of a holden red motor ,would anyone know of any other connection points that an additional sensor can be connected.There is a disconnected sensor installed between plugs 1 & 2 of the head ( ON THE CAR WE PUCHASED )and when removed looked like it had a spot of oil on it.Does anyone know if this is a spot to install an additional sensor.
#2 Posted : Sunday, 20 September 2009 3:52:23 AM(UTC)
No, that location on the head is for a temperature sensor/switch, it just senses the temperature of the metal.
With oil pressure sensors or switches, you can t-piece as may as you like at the one outlet (near the oil pump) & they will all work fine. You cant do that with water temperature sensors.
Mr Void Offline
#3 Posted : Sunday, 20 September 2009 4:02:50 AM(UTC)
Mr Void
^ So if the extra switch doesnt fit on a T-piece you may have to run a line away from the fitting with the switch mounted remotely
___________________
Why are you reading this, you should be looking up there^^
___________________
