peter_flane Offline
#1 Posted : Thursday, 24 September 2009 7:51:02 AM(UTC)
peter_flane
I know it is the same stud pattern. Will the offset fit? I am only talking same size width and diameter tyres as EH 185/75/13
http://www.ehlimo.com.au/
#2 Posted : Thursday, 24 September 2009 8:12:21 AM(UTC)
the HK have a different offset and will rub on the inner rear arches
#3 Posted : Friday, 25 September 2009 12:46:23 AM(UTC)
As John said but HT or HG should fit as they changed the offset back again.
If at first you dont succeed then skydiving is not for you.
vintageholden Offline
#4 Posted : Friday, 25 September 2009 3:41:13 AM(UTC)
vintageholden
got hk/t/g/ on my eh and my fb and they dont rub
Edited by user Friday, 25 September 2009 3:41:45 AM(UTC)  | Reason: Not specified
#5 Posted : Friday, 25 September 2009 8:50:07 AM(UTC)
I fitted ht/hg to my Eh wagon and they rubbed on the inner rear panel on cornering, not all the time, I had to panel beat the stiffening ridges on the panel flat and they were ok then, but hk ones just would not work, from memory they rubbed on the brakes calipers as well, but I had HK disk brakes on the HR front end.are you sure you have hk wheels?
#6 Posted : Saturday, 26 September 2009 5:27:35 AM(UTC)
vintageholden
might be ht
#7 Posted : Saturday, 26 September 2009 9:25:34 AM(UTC)
hk rims have a series of holes or slots around them, ht/hg are a plain solid rim
peter_flane Offline
#8 Posted : Saturday, 26 September 2009 9:47:58 AM(UTC)
peter_flane
Thank you for your help. I appreciate the help and knowledge. This makes the forum what it is.
