Holdenon Offline
#1 Posted : Monday, 28 September 2009 3:42:46 AM(UTC)
Holdenon
Can anyone decode theses mudflaps part numbers,
PART NO 92021181 & 92021182
Edited by user Wednesday, 30 September 2009 7:35:13 AM(UTC)  | Reason: Not specified
Tour Director Offline
#2 Posted : Wednesday, 30 September 2009 2:02:58 AM(UTC)
Tour Director
These are WB Statesman rear mudflaps. part numbers 9932288 and 9932289 also refer in the parts book.
Holdenon Offline
#3 Posted : Wednesday, 30 September 2009 7:11:40 AM(UTC)
Holdenon
Thanks TD,
Ill add that to my mudflap reference lists. I am trying to find rears for a HQ ute in good condition,
cheers,
Scott
Holdenon Offline
#4 Posted : Wednesday, 30 September 2009 7:33:32 AM(UTC)
Holdenon
As a follow up I found in my records that:
2820347-2820346 are rears for all HQ and HJ-HZ Panel Van, Utility, Coupe, Statesman.
Therefore the mudflaps 92021181-92021182 for a WB Statesman should be alright for a ute?
9932289-9932288 are rears for HJ-HZ Sedan and Station Wagon, i bought a set accidently thinking the wagon would be the same as a ute - not so.
Rhys Offline
#5 Posted : Wednesday, 30 September 2009 9:06:20 AM(UTC)
Rhys
Holdenon,
The WB Statesmans are quite wide towards the base of the boot, and therefore have unique rear mudflaps. Its easy to tell by looking at the mudflaps as the outside top bit (long side) is quite narrow compared to the others.
Have a look around for HQ-HZ Statesmans for wrecking, as a lot of them will still have the original mudflaps if that it what youre after, although you may find that the steel braces are rusted out on most.
Rhys
Holdenon Offline
#6 Posted : Thursday, 1 October 2009 4:26:20 PM(UTC)
Holdenon
Rhys,
Thanks, great info - didnt realise there was so much difference between the Statos. Explain why the WB part number is only for the Statesman.
