#1 Posted : Thursday, 8 October 2009 2:59:03 PM(UTC)
Hi all
Will soon have my G back on the road.
I've just bought it, but I've been assured all the mechanicals have been rebuilt (probably 5-6yrs ago)
HT block 308 with VP heads, Supra 5 speed with new clutch, Ford 9" LSD (seems pretty tight) and rebuilt disk/drum brakes.
So I'm going to treat it like everything needs running in.
Any advice re fluids and techniques?
Jvanner Offline
#2 Posted : Thursday, 8 October 2009 11:20:47 PM(UTC)
Jvanner
in my van i ran the motor on cheap woolworths oil for 1000k. done an oil change and ran the motor on medium brand 30 grade oil. white driving around i let the motor work alittle when going up hills and not so much in high revs when gearing down coming down a hill.
#3 Posted : Friday, 9 October 2009 1:35:01 AM(UTC)
308 is big enough to drive normal,but dont over rev it,keep altering your speeds and check for leaks every day for a while,(as above) Jvanners right as well ,then use good oil when run in,(slick 50 is great stuff)just my opinions...jim
Jim in adelaide
HQforme Offline
#4 Posted : Friday, 9 October 2009 2:40:11 AM(UTC)
HQforme
Depends how much use it had? If its like a brand new motor, you want high quality non-synthetic oil for break-in. Run the motor for ten mins or so, varying revs up and down, but not idling, to break in the cam. Hopefully the assembly lube is still in place if the motor has just been sitting. When you start driving, avoid revs, but dont baby it, you could glaze the bores. Hills are good, load but not high revs.
If it was run for a bit, hopefully the cam was bedded, and with some good oil, you can pretty much just drive, without high revs and not babying the thing.
"Silly modern cars"
#5 Posted : Friday, 9 October 2009 7:58:42 AM(UTC)
Thanks all
I know its been started a few times to get it on and off trailers, but it doesnt have an exhaust at the moment, so it was never for long.
Also, without the right sensor etc. the throttle would have been tickled a bit to get it to settle down.
Ill do the 10 minute thing when the exhaust goes on and then get it home.
Ill get some GTX II 20-50W oil and change it with a new filter before I start running it in.
Will have to start running it in on its way to get a blue slip....
Thanks for the advice.
peter_flane Offline
#6 Posted : Friday, 9 October 2009 8:40:13 AM(UTC)
peter_flane
My motor had a 10 minute run under load on a dyno to bed the cam in, then I was told go hard and push it to the floor continuously in all gears for the next 500 ks but dont rev it over 6000. Then the oil was changed and no limits.
http://www.ehlimo.com.au/
castellan Offline
#7 Posted : Saturday, 10 October 2009 3:46:32 AM(UTC)
castellan
Who has ever seen a motor that had a problem with it, because it was driven to hard when running it in. never!
all ya do is watch it dont get to hot. keep ya ears open and keep a eye on the oil pressure.
A lot have buggered a motor by babying it.
Sandman Offline
#8 Posted : Saturday, 10 October 2009 6:32:20 AM(UTC)
Sandman
Yeh, Castellan, Ill go along with that.
With engine parts and oil quality the way it is these days, theres no need to go putting around running engines in.
I recommend only running for a very shory time, 1/2 hr to an hour, drain the oil and change the filter. This will hopefully get rid of any crap that was in the engine while getting built, (lint, dust etc) also if moly lube is used on a new cam it can block oil filters.
Then run a running in oil. I use Penrite, probably others around. Drive the car like normal or harder. Load it up in higher gears to make the rings bed in. Change to whatever oil you plan on running after about 500Ks.
Yrs ago when I was fulltime mechanicing, I used to fire them up in the workshop, warm them up, check for leaks, noises, etc. Drive out of town about 10ks, stop, check everything again, then drive back to town, flat in top gear. Never had a failure or an engine back.
HQforme Offline
#9 Posted : Saturday, 10 October 2009 9:06:00 AM(UTC)
HQforme
Um, nobody said "putt" the engine in. We all said dont putt around!
One good point raised was the assembly/moly lube possibly clogging filters. Thats why you cahnge the oil and filter after the run-in period. This is a must.
"Silly modern cars"
