#1 Posted : Thursday, 5 November 2009 7:42:14 AM(UTC)
Brains trust
I need to shorten the accelorator cable on the G.
Does anyone have a legal way to do this or some company who I can post it to for the deed.
PS - Im near Canberra.
#2 Posted : Thursday, 5 November 2009 7:58:37 AM(UTC)
Was thanked: 616 time(s) in 583 post(s)
Whats in it now? VN V6 may work if it has a HQ-HW V8 one in it and you have an EFI 304 now.
#3 Posted : Thursday, 5 November 2009 8:03:03 AM(UTC)
Not sure what the cables out of.
I assume it might be the VN V8 commodore one.
Its about 1-2 inches too long....
adam PERTH Offline
#4 Posted : Thursday, 5 November 2009 8:56:46 AM(UTC)
adam PERTH
get a HJ-WB 6 cyl one.
they are about 2 inches shorter than V8.
WANTED:
-2 14 x 9.25 CSA style Centrelines.
-2 x 15 x 8 Dragway centrelines
#5 Posted : Thursday, 5 November 2009 3:48:01 PM(UTC)
Question ,can you run a 6 cyl cable on a V8 redirecting it thru the back way of the engine near the firewall and hooking it up to the top of the acc linkage? as they normally go all around the front in a big(ugly)loop.(roch /holley)
Jim in Adelaide
Edited by user Thursday, 5 November 2009 3:49:08 PM(UTC)  | Reason: Not specified
adam PERTH Offline
#6 Posted : Friday, 6 November 2009 10:12:58 AM(UTC)
adam PERTH
yep. only just...
WANTED:
#7 Posted : Friday, 6 November 2009 4:05:49 PM(UTC)
HI Adam ,have you done this as im thinking about it.?
Jim in Adelaide
#8 Posted : Sunday, 15 November 2009 8:26:02 AM(UTC)
Gents
Surely theres a way of shortening and not replacing.
Dodgy way would be to use one of those screw on dodads from the bonnet cable.
Or maybe a more pemranent swaged on version somehow??
Any ideas??
monarosteve Offline
#9 Posted : Sunday, 15 November 2009 10:17:47 PM(UTC)
monarosteve
I have had some accelerator and speedo cables made by ...http://www.autocables.com.au/ He has a really good workshop and would probably take him about 5 minutes to make you one to any length you want AND is reasonably priced.
Without seeing your setup, i cannot see how a longer cable is even a problem if you have appropriate brackets mounted to ensure the cable is taut at both ends. I had a cable on my car that was probably 1 1/2 foot too long but worked fine for this reason, only changed it over for aesthetic reasons.
playwme Offline
#10 Posted : Monday, 16 November 2009 6:52:04 AM(UTC)
playwme
Better off fabricating a new mount for your standard off the shelf cable. If you run a modified one and the cable snaps while on a road trip youre a bit stuffed. Standard off the shelf cable you can walk into repco and get the right one nice and easy.
#11 Posted : Friday, 20 November 2009 6:44:48 AM(UTC)
speedscreen in nth melb
I innovate, never imitate..
