Mnbvcxz123 Offline
#1 Posted : Monday, 9 November 2009 5:10:42 AM(UTC)
Mnbvcxz123
Does anyone know if the HQ V8 motor mounting points are availble new as I want to install the rebuilt 253 into another vehicle for towing and also does anyone know where I could get good used mounts and a M21 4 speed transmission mounting thing, its the bit that mounts to either side of the chassis that the gearbox mounts onto. In Qld would be better.
old fella Offline
#2 Posted : Monday, 9 November 2009 7:05:38 AM(UTC)
old fella
they will fit straight into where your 6 cyclinder engine mounts are,and same with the gearbox mount,repco sell new mounts, hope this helps
Mnbvcxz123 Offline
#3 Posted : Thursday, 12 November 2009 4:30:24 AM(UTC)
Mnbvcxz123
Im after the mounts that are welded to the subframe are they available new.
#4 Posted : Friday, 13 November 2009 3:06:01 AM(UTC)
CRS do them to convert early Holden up to EJs to red/blue/black engines.
If at first you dont succeed then skydiving is not for you.
