tyco007 Offline
#1 Posted : Tuesday, 17 November 2009 2:52:33 AM(UTC)
tyco007
I have a Holden Astra 1988 1.8 EFI. The engine randomly cuts out whilst driving. It usually starts ok and whilst driving the revs drop to an idle and when you accelerate the engine cuts out. It starts again a couple of hours later.
Have replaced with new Fuel Pump, Filter and regulator. Has new plugs and leads. Even drained the fuel.
Replaced with secondand Fuel Relay and Dizzy.
Any help would be greatly appreciated.
Paul351xb Offline
#2 Posted : Tuesday, 17 November 2009 5:57:48 AM(UTC)
Paul351xb
Id be checking the coil, electrics. Sounds like something is failing under load once you get some heat in the system.
"Life, a series of events, woven into a tapestry which becomes our destiny"
