hi was wondering if anyone can help work out if my vb has the sports pack or not it has 4 wheel disc brakes full instrumentaion and headlight washer wipers the plates read as follows
model 8vk69br body 513366-s trim 1189-63v paint 568-10981 eng l36 trans m20 axle gu4
vin 8k69rkh513366b avb 039359s
thanx to any 1 that can help
Its a Sydney build, which generally dont have the option pack code stamped on the plate, so it will be pretty much impossible to tell.
Apart from really, really early VBs (the first month or 2) all V8 commodores had 4 wheel discs standard. Manual V8s also scored the full instruments.
model 8vk69br = Base model VB sedan. body 513366-s = sequential body number from the Sydney assembly plant (Pagewood) trim 1189-63v = 1189 - Firethorn Red exterior = 63V - Buckskin vinyl interior trim paint 568-10981 = Firethorn Red eng l36 = 4.2L V8 trans m20 = Aussie 4 speed manual axle gu4 = 3.08:1 diff ratio.
