Mark HK Offline
#1 Posted : Monday, 7 December 2009 6:40:32 AM(UTC)
Mark HK
hi will ht sedan doors fit a hk brougham? mainly the back doors and will the power windows fit by just cutting out the holes for the switch and cable?
thanks Mark
#2 Posted : Monday, 7 December 2009 8:22:50 AM(UTC)
Hi Mark.
The front doors will be OK. The rear doors will fit but will not line up properly with the rear pillar. They just wont look right.
Power windows will fit as you described.
Dr Terry.
There are only 3 types of people in the world.
1. Those who make things happen.
2. Those who watch things happen.
3. Those who wonder what happened.
#3 Posted : Monday, 7 December 2009 9:24:23 AM(UTC)
Hi Mark
Would really appreciate some photos of power windows installed - particularly the cable from body to door and how the switches fit in the door cards.
Assuming of course that its factory fitment and not aftermaket.
Power windows is project 9870 on the to do list....
kelvin01au Offline
#4 Posted : Tuesday, 8 December 2009 7:36:26 AM(UTC)
kelvin01au
brougham doors. i think that in the deep dark recesses of my mind i remember that maybe wagon doors are the same. please let me know if i am all (you know the word) up
#5 Posted : Tuesday, 8 December 2009 10:51:10 AM(UTC)
Hi Kelvin , you are partly right , all HK HT HG brougham rear doors use the same skin as all HKTG wagons (curves upwards at the top ) .
The wagon door frames are squared off at the top though so the actual door is different . All HK sedans used this skin also .
But all HT HG Belmonts , Kingas and Prems Sedans used a different skin/door frame as the body line got lower and did not have the upswept curve . Are you confused now !
Hope this helps
James
www.monaromuscleparts.com
#6 Posted : Tuesday, 8 December 2009 7:08:39 PM(UTC)
Ill have to disagree on that point James.
All HT/HG 4-door sedans, including Brougham had the lower window-sill line on the rear doors. The higher window-sill line as seen on all HK sedans & wagons, was only retained on the wagon body style for HT/HG.
All four door panels for Brougham were always the same as Belmont, Kingswood & Premier sedans for each model series. The part numbers differed for those with power windows because of the slightly different holes made for the wiring & switch etc.
#7 Posted : Wednesday, 9 December 2009 4:16:39 AM(UTC)
Please Read my post again Terry , that is exactly what i have written . You must have read it quickly or something . cheers James
#8 Posted : Wednesday, 9 December 2009 5:02:00 AM(UTC)
But James, you wrote this :-
"Hi Kelvin , you are partly right , all HK HT HG brougham rear doors use the same skin as all HKTG wagons (curves upwards at the top ) ."
This is not correct, the HT/G Broughams use HT/G Belmont/Kingswood/Premier sedan doors, not wagon doors (ignoring the upper window frame), or that just me misinterpreting what you have written.
#9 Posted : Wednesday, 9 December 2009 6:00:33 AM(UTC)
james could be on the vinyl glue again???
"theres a hole in shoe"...hahaha
I innovate, never imitate..
#10 Posted : Wednesday, 9 December 2009 6:18:52 PM(UTC)
Yes Frank you are right ,but it spray fumes at the moment for me Painting my Panel Van not vinyl glue , wrong James there old son.
And Terry you are right also , i know what i meant but have written it wrong , lucky you are here !
#11 Posted : Wednesday, 9 December 2009 8:03:35 PM(UTC)
i know which james is james and which james is you james..painting car huh? acrylic?? ewwwwwww hahaha..gee i must have nuffin to do again
Edited by user Wednesday, 9 December 2009 9:54:38 PM(UTC)  | Reason: Not specified
Mark HK Offline
#12 Posted : Thursday, 10 December 2009 4:27:41 AM(UTC)
Mark HK
Thanks for info
Ill try to get some pics of the window switch and cable holes on the weekend
What about the boot lid is that the same as ht hg or is the hk brougham diferen
Mark
Keeo Offline
#13 Posted : Thursday, 10 December 2009 5:19:24 AM(UTC)
Keeo
Gee interesting stuff. I was half way out the back door(of the house)to check me hk wagon door against me old hg sedan door an realised i need a brougham rear door to look at .Its the only way i can get me head arround it.Sorry im no help.--keeo ps so is answer no ht sedan door wont fit hk brougham?
#14 Posted : Thursday, 10 December 2009 5:21:37 AM(UTC)
Thanks Mark
Would really appreciate the pics.
Guest (7)
