melissa Offline
#1 Posted : Friday, 11 December 2009 9:05:42 AM(UTC)
melissa
does anyone know how i can turn my immobiliser off as i wasnt given a key for the darn thing when i got it and cant afford to get a mongoose key at moment thanks
Edited by user Friday, 11 December 2009 3:03:03 PM(UTC)  | Reason: Not specified
#2 Posted : Friday, 11 December 2009 4:08:47 PM(UTC)
You have to access the back of the lock itself.
There are 4 wires on it (only 2 colours - so 2 of each colour).
Leave one pair of colours open-circuit.
Join the other pair of colours (Im not going to say what colours on a public forum).
#3 Posted : Friday, 11 December 2009 10:15:19 PM(UTC)
Are you saying that you dont have the button box or you dont have the little ZADI key or the button box?
If at first you dont succeed then skydiving is not for you.
vintageholden Offline
#4 Posted : Friday, 11 December 2009 10:38:55 PM(UTC)
vintageholden
if its factory..there is a switch on the passengger door as you open it ....if you have the key ,turn it off
just noticed you dont have the key...
Edited by user Friday, 11 December 2009 10:39:41 PM(UTC)  | Reason: Not specified
melissa Offline
#5 Posted : Saturday, 12 December 2009 1:01:09 AM(UTC)
melissa
theres no key or button on passenger side
#6 Posted : Saturday, 12 December 2009 1:19:35 AM(UTC)
?? The button is on a black box that goes on your keyring, costs about $200 with programming and then dies completely when its just over a year old (well in my experience it did).
The lock to disable the immobiliser is in the passenger side front door jamb near the hinges. This is turned on an off using a small key with "ZADI" written on it. it might have a black cover over the lock but it will be there.
With the immobiliser on your car will flash "use remote" on the dash as soon as you turn on the ignition.
So you are saying that you are missing both the ZADI key and the button box yes? If so then you need to follow Micks advice on bypassing the lock in the door jamb.
melissa Offline
#7 Posted : Saturday, 12 December 2009 2:01:13 AM(UTC)
melissa
yes thats what im saying i dont have the zadi key or the button box ill get my partner to try that now hopefully it works thanks all for the help :)
melissa Offline
#8 Posted : Saturday, 12 December 2009 2:03:00 AM(UTC)
melissa
your right jim the box is there on passenger side and is flashing saying use remote
melissa Offline
#9 Posted : Saturday, 12 December 2009 2:09:49 AM(UTC)
melissa
he tried that hes got no idea hes an idiot now theres not even any reds ??? whats happened
melissa Offline
#10 Posted : Saturday, 12 December 2009 4:48:15 AM(UTC)
melissa
ok i got it going thanks mick he wired it and it worked thanks sooo much for your help and 2 everyone else for their help also ur legends
fxnrg2 Offline
#11 Posted : Monday, 22 March 2010 7:36:21 AM(UTC)
fxnrg2
were is the main loom found for the isolation switch (zadi key lock in passenger sige door jam)the isolation switch has bein smashed out while some1 trying to steal my car and cant not find thethe 4 wires that can be brigde and started as car is not starting and central locking not working only drivers door is
grrrrrrrrrrr
grrrrrrrrrrr
lildog Offline
#12 Posted : Tuesday, 23 March 2010 5:35:59 AM(UTC)
lildog
In the left kick panel is the ECU. It has one pink wire if you place a bridge wire from this pink wire to the pink wire in the data connector, which is the white block located under the glovebox, this will bypass the immobiliser. Hope this helps.
