Fastlane
Holden Forums
Holden General Discussion
L76 6.0 & 6 speed into hz 1 ton ute...MODS?
i am looking at donor car ve ss 6.0lt (L76) with 6 speed manual box what extra parts are needed to make the conversion smooth... i.e. Mounts, Gauges, ect.
What problems will i encounter?
Does the ve sump fit?, I heard that they have the sump that fits?
Can someone give me a comprehensive run down
I think your biggest problem is the 6 speed wont fit in the standard tunnel, meaning massive floor/tunnel mods and associated Engineering. An auto should be a better fit. If you want a manual it might be worth just buying a VY or VZ V8 6spd tonner?
Fastlane
Holden Forums
