buggerme Offline
#1 Posted : Tuesday, 29 December 2009 12:03:44 AM(UTC)
buggerme
Hi just looking for information regarding fitting a Tremec TKO600 in a HK Monaro how much work is required in fitting one. What did you do about the the 3" crossmember that would need to be cut for the shifter to come through. Does the whole tunnel need to removed or can you get away with a tunnel hump that some did have.
Sandman Offline
#2 Posted : Monday, 4 January 2010 7:19:36 AM(UTC)
Sandman
Try ringing Mal Wood at Warwick Qld. Hes an agent for tremec
