ausnetgrouplimited Offline
#1 Posted : Tuesday, 5 January 2010 12:38:59 AM(UTC)
ausnetgrouplimited
Hey All
Recently had some problems with my alternator on a NC 1994.
Have now replaced it with a new one.
Everything seems fine although the car radio and power windows dont work.
The CB 30amp fuse in the slot on the fuse panel has been replace and still no joy.
Looking for any ideas tried or that can be tested relating to this issue.
Colesy Offline
#2 Posted : Tuesday, 19 January 2010 6:39:12 PM(UTC)
Colesy
have u try the relay, use a test light and c if power is geting to the window and radio and double check all fueses. good luck(im a mechanic but electrics is not my strong point)
#3 Posted : Wednesday, 20 January 2010 3:02:05 AM(UTC)
Without stating the bleeding obvious is your radio asking for a code or not even getting that far?
As for the power windows I had to change my EB alternator a month or so ago and had none of the side effects that you describe. There is a relay bank c
