greenhj Offline
#1 Posted : Friday, 8 January 2010 4:28:42 AM(UTC)
greenhj
Is there a particular reason why the pulley size changed?
Is there any difference in pumping efficiency between the short and long snout pumps?
On 2 v8 tonners im playing with they have a pulley very close to 1:1 with the balancer pulley.
They both look like long snout pumps, pulley seems to be around 150mm diameter
One is HZ, the other is WB.
I have a short snout pump (genuine holden, VT i think) on my stroked 308, and the pulley im using is smaller than the above mentioned, (could be hz sedan pulley, i dug it out of the shed years ago)
it measures around 138mm.
I like the idea of slowing the water pump down on an engine that idles at 1100rpm, spends most of its time cruising between 3000/3800 rpm and turns to 6700.
Are there any downsides to this?
11.38@117
Edited by user Friday, 8 January 2010 5:24:48 AM(UTC)  | Reason: Not specified
#2 Posted : Friday, 8 January 2010 6:16:16 AM(UTC)
The smaller diameter water pump pulley was fitted to V8s with factory a/cond. It was to run the fan & water pump run faster, to help with cooling & a/cond operation at low RPM.
There are only 3 types of people in the world.
1. Those who make things happen.
2. Those who watch things happen.
3. Those who wonder what happened.
greenhj Offline
#3 Posted : Friday, 8 January 2010 7:32:21 AM(UTC)
greenhj
cheers doc.
I might just bung on the larger pulley and see what happens, i imagine it will get plenty of water flow at my rpm parameters without the overdriven pump, and the belt driven fan is long gone.
11.38@117
