commo Offline
#1 Posted : Sunday, 31 January 2010 12:53:07 AM(UTC)
commo
Hi guys, i got my vh running after 8 years being parked in the garage without being driven, no surprise that a few things dont work theres 2 that i hope someone can help me with , the tacho has stopped working and the lightsin the speedo-tacho bubble dont work ,ive checked the fuses lol what else could it be?
any one can help
many thanks.
#2 Posted : Sunday, 31 January 2010 1:08:44 AM(UTC)
Pull the dash facia out,give it a clean and check,then hit it with a little WD40....see how you go.or put your hand up the back an play around?...lol
#3 Posted : Sunday, 31 January 2010 6:04:47 AM(UTC)
if it cant be fixed with a hammer, its a electrical fault
commo Offline
#4 Posted : Sunday, 31 January 2010 6:59:39 AM(UTC)
commo
lol when i said i changed the fuse that pretty much killed any chance of a helpfull tip j/k
thanks
#5 Posted : Sunday, 31 January 2010 7:22:51 AM(UTC)
haha, just check all the conections and earths, probley just a bit of corrosion or excessive dust on a terminal or loose earth, also check everything is tight
id also give it a tap and call it a cu*t, even if that dont work youll feel better after it, lol
commo Offline
#6 Posted : Sunday, 31 January 2010 10:23:20 AM(UTC)
commo
can you draw me a picture :) seriously!
Are VH group3 rear springs standard holden springs ? i cut mine and its too low :(
