#1 Posted : Thursday, 3 March 2005 7:28:14 AM(UTC)
My UC Torana was originally fitted with factory aircon. Now disconnected. The problem is that even when set to demist all the fan air flow comes out the central vents. No matter what position the vent lever is set to (demist, floor, heat, etc) all the air still comes out the central vent. I hear that this was how the factory air was set up. How do I undo this so I can get normal air flow using the fan?
#2 Posted : Friday, 4 March 2005 3:18:19 AM(UTC)
Hi UC DAN.
Does your A/Cond have its controls incorporated with the heater controls.
If so it shouldn't work as you have explained, it sounds like a vacuum line may have been disconnected somewhere.
Check the vacuum plumbing & get back to us.
#3 Posted : Saturday, 5 March 2005 6:16:28 AM(UTC)
Dr Terry, Yes A/Cond controls are incorporated with the heater controls. I thought I would be able to still use the demister by using the lever to direct the fan airflow to the windscreen vents but little air seems to come out there. I was not expecting
