Thanks: 4 times Was thanked: 2 time(s) in 2 post(s)
Gday fellas, I need to change my HK's stud pattern to HQ and want to know the best way to do it. I've heard it's too hard to have them redrilled on HK for some reason so would it be better to get another diff? I want to keep it GM, preferably 10 bolt so which ones will fit HK with minimal mods?? Cheers, Glenn.
New axles is probably the simplest if you can find someone to make them. Just leave the HK backing plate and HQ drums should go straight on. Otherwise a VN Commodore diff conversion, and then get those axles redrilled to HQ.
