What is my holden?Small tag=80569kh527860,Big tag=Body 80569KR-03974-H5,Trim 1172-18R,Paint 568-10845,Firewall=HK-232865,S,Engine=307*****K10 13 |
Water makes it's own sauce |
HK Premier, the 3974th of its kind from Pagewood plant. 1172 is Ermine white paint, and 18R is Buckskin trim. By the chassis number its a July 1968 build, and chassis number is HK23286SS. Engine number will be close to 30712750K1013 +/-100 or so GMH numbers.
Depends on its condition. Can you PM me and let me know how close I was with the engine number?
Byron, I reckon you can just about look at a car an guess the engine number by now,thanxz for all your research that Ive read its been exceptional.
Jim in Adelaide...Hindsight is bad vision! |
Jim in Adelaide.. |
Only on Pagewood HK and to some extent on late HQ-HZ.
quote: Originally posted by HK1837
Depends on its condition. Can you PM me and let me know how close I was with the engine number?HK dude,you were roughly 350 out(over).It has rust in guards,quarts,boot.Doors,sills&floors are cool.Running gear is mint.Paint will still shine.GTS dash&boot garnish&b/lock dress up ring.4 barrel,new hurst shift,new extracts.
If its that good expect $20k+ for it. The non original stuff might drag it back a bit.
So it was close to 30712400?
HK1837,you were so close to 30712400 its eerie(less than 50 away!)I dont want to overrate it All the body rust isnt terminal.Boot floor is effed,have whole floor out of another Prem.Some spare panels.Read my last entry just above yours.Thanx for your help,champ.Mick G |
OK, I missed the bit about rust. Will take a guess at $5k - $12k. Big range I know but V8 HK Prems are rare. If you want to sell it stick it on Ebay and see what happens!
I agree with Byron if your a seller EBAY IS THE PLACE as I said before "to the right person".an ebays got lots of them.
Jim in Adelaide.. |
