Thanks: 1 times Was thanked: 618 time(s) in 584 post(s)
Anyone know where to buy one of these?
Mine is a 3 way vacuum operated. I got a good vaccum operator of Dr Terry today, but I need the switch part as it and my original are all rotted out. Rares have a 2 way version but I cannot find a 3 way.
Thanks: 1 times Was thanked: 35 time(s) in 33 post(s)
Do you want the vacuum operated valve that goes in the heater hoses? If so, Ecotec V6 commodores run a 4 way one - you could cap off the 4th port.
Or you could plumb the system like a VS-VY where the heater core is entirely bypassed when the tap is "off" - the water is rerouted back to the water pump, instead of being dead-headed at the valve.
Yeah Mick, its the valve in the heater hoses. Im trying to make the HJs engine bay look as original as possible or id make something up.
Just thinking along the lines that a lot of GMH gear from the era has its origins in US GM. Havent looked into this site, but it might help. http://www.who-sells-it....eater-control-valve.html
