Matty Q Offline
#1 Posted : Tuesday, 16 March 2010 4:07:42 AM(UTC)
Matty Q
Hi there
Is there a way of telling the diff ratio without removing the diff? I have a very noisy diff I want to replace with second hand one, was hoping to pick one up before putting the car out of action. Its a standard Salisbury, 72 HQ Premier, 202 Trimatic. All stock standard.
Matt
Holden man working on a Ford.
Continually amazing how people are willing to share information.
#2 Posted : Tuesday, 16 March 2010 4:17:54 AM(UTC)
standard salisbury...
by the front of the diff there is a steel ring around the front by the diff tailshaft yoke....it will have 3.08 or 3.55 stamped in it, if you are still unsure the crown wheel will have the numbers stamped in it,so take off the back plate and spin it around untill you see the ratio numbers (2.78 3.08 etc).
Edited by user Tuesday, 16 March 2010 4:18:29 AM(UTC)  | Reason: Not specified
Matty Q Offline
#3 Posted : Tuesday, 16 March 2010 4:23:10 AM(UTC)
Matty Q
Thanks Jim.
#4 Posted : Tuesday, 16 March 2010 6:17:04 AM(UTC)
Matt
Stock standard HQ 6cyl Premier will be a banjo. So it must have been changed at some stage.
Matty Q Offline
#5 Posted : Tuesday, 16 March 2010 9:17:47 AM(UTC)
Matty Q
No, nothing changed, realised about an hour ago I had had a brain fade. Its a banjo. 3.35 from what I can read of the yolk plate - that sound right?
#6 Posted : Tuesday, 16 March 2010 5:14:59 PM(UTC)
Yes.
#7 Posted : Wednesday, 17 March 2010 2:26:35 AM(UTC)
3.36 ? that sound righter?
Matty Q Offline
#8 Posted : Sunday, 21 March 2010 6:14:58 AM(UTC)
Matty Q
Yeah, check & its 3.36 for sure. One on sale on eBay, says its out of a HR - they would be the same diff, yes?
#9 Posted : Sunday, 21 March 2010 7:51:12 PM(UTC)
different i think get a hq one there is lots of them,as a matter of fact i know they are different the wheels arent interchangeable.....get a hq one
Edited by user Sunday, 21 March 2010 7:51:46 PM(UTC)  | Reason: Not specified
classic oz wreck Offline
#10 Posted : Sunday, 21 March 2010 9:15:08 PM(UTC)
classic oz wreck
the centre will be interchangable as long as it has the correct splines in the diff centre...hq should have coarse spline axles and all hr were coarse spline....only way it could go wrong is if someone has put hx hz fine spline centre and axles in your hq..
www.classicozwreck.com.au
Matty Q Offline
#11 Posted : Monday, 22 March 2010 1:30:25 AM(UTC)
Matty Q
Gotcha. Its advertised as course spline, so think I should be right. Thanks Jim.
