scrappy Offline
#1 Posted : Tuesday, 16 March 2010 8:12:46 AM(UTC)
scrappy
i have been tring to find out why my HZ tonner stopped runing when i let the key snapped back to the on position after starting it. after pulling most the dash out tring to find the resistor wire i found a burnt out spliced wire that had piggy backed another wire that was conected to (forgive the lack of technical terms) a white... plastic hub? that is connected to a metal rod that ran back up to the ignition barrel so long story short im sh*t caning the immobiliser and i need the ignition rewired the immob is.....was wired into everything. so how hard will rewiring be for a... novice
