bundybluedog Offline
#1 Posted : Saturday, 20 March 2010 8:08:13 PM(UTC)
bundybluedog
Seeing that my torry in only gunna be a cruiser im thinking of foing the BW diff but im wanting to keep the torana stud paturn and use either 13 inch sprintmasters or 13 inch jelly beans for my wheels. Will this all work with the disc brake rear end on small wheel? I havent got a diff of wheels yet so i have no measurements but any info would be good.
Utility8 Offline
#2 Posted : Sunday, 21 March 2010 1:41:12 AM(UTC)
Utility8
14s will be the minimum you can fit without modifying caliper mount & rotor diameter. Stud pattern change will most likely, if done correctly, require new axles. The diff housing will also require shortening. Keep in mind the inner guard interfering with the calipers too. Rather involved job for a cruiser when a standard banjo works OK.
Utility8
utility8
#3 Posted : Sunday, 21 March 2010 7:42:53 AM(UTC)
bundybluedog
i knew i would have to shorten it just wasnt sure on caliper clearance. now that the laws didnt get changed in QLD i wanna stick to the origanal plan of injected 5 litre with the 5 speed so the old bango may have to go. i have most of the gear just need to get another injection setup as i sold the engine i had for it when i was told it was now illegal. if its not the 5 litre it will be a superchared 202 so even then the BW will be a better option
