78XC Offline
#1 Posted : Sunday, 21 March 2010 8:48:46 AM(UTC)
78XC
Hi I have a Edelbrock 4V Torker manifold, and was told that you can fit a 4v manifold on 2v heads as long as you match port the inlets does anyone know if this is true cause I don't want to get rid of the manifold if I can help it. thanks
Docktor Offline
#2 Posted : Sunday, 21 March 2010 1:19:48 PM(UTC)
Docktor
I really think u have to either dump manifold or heads mate. Thats a huge port job. In my personal opinion. not gunna happen
russxr67 Offline
#3 Posted : Monday, 22 March 2010 3:55:34 AM(UTC)
russxr67
Yes,it will fit without a problem,however a 4V Torker is much larger at the manifold end.
Dont bother with matching as the deliberate mismatch is not a real issue. It might not look right but it will work fine.
Keep in mind the Torker is a single plane manifold as well and is suited to fairly healthy engines with an empahsis on top end power production.
78XC Offline
#4 Posted : Monday, 22 March 2010 8:20:25 AM(UTC)
78XC
Yeah I dont really know what Im doing....
I was told that if you match port them then you are going to go from a large port size to a small port size compressing the gasses once again Im not sure.........
