#1 Posted : Friday, 26 March 2010 6:40:37 AM(UTC)
Evening team from the dark side.
I'm really stuck on this Volt meter conversion of the G's ammeter.
Instrument man cannot convert the ameter to voltmeter.
He could convert a temp, fuel or oil pressure guage if I could find him one that fits.
The rub is it needs to point down and move from left to right.
Movement needs to be small like the original ammeter. Best bet is Holden/Ford/Valiant from late sixties to early eighties.
Can anyone help - need movement only and I don't think it would need to be working.
Here's a pic of the ammeter to show you what I mean.
6pak Offline
#2 Posted : Friday, 26 March 2010 11:31:53 AM(UTC)
6pak
The XB Falcon had a volt meter with a needle that pointed down on the GS dash didnt it? Its already set up for volts too which could save some mucking about. Hope this helps.
#3 Posted : Friday, 26 March 2010 5:50:19 PM(UTC)
Thanks 6pak
Yes youre right.
Found one on ebay, but its the whole dash full of GS instruments and itll probably go for heaps. Might be OK though Ill keep an eye on it and see how I go.
Would anyone have one they can part with??
