#1 Posted : Tuesday, 8 March 2005 4:16:04 AM(UTC)
i have a HR with a 186 and a powerglide and i can get a 308 and a powerglide would it be a ezy swap if i could find a sump to fit??
will the gearbox still endup in the same place or not
i know the brakes ,diff and radiator will need to be changed
#2 Posted : Tuesday, 8 March 2005 5:05:44 AM(UTC)
The V8 powerglide has it's rear mount in a different position, and the speedo cable is on the wrong side. I've seen this conversion done before though.
Dylan Offline
#3 Posted : Wednesday, 9 March 2005 3:28:52 AM(UTC)
Dylan
before touching anything find an engineer that will let you do it.
#4 Posted : Wednesday, 9 March 2005 5:03:55 AM(UTC)
Hi Mark.
If you swap the rear extension housing from your old 6 cyl Powerglide box onto the V8 one, you can use your existing crossmember, tailshaft & speedo cable.
Dr Terry.
