#1 Posted : Sunday, 22 August 2004 11:29:29 PM(UTC)
wanting to buy a front cut of a quad cam ba xr8 email [email protected]
#2 Posted : Monday, 23 August 2004 4:32:12 AM(UTC)
What do you want to put the engine in? Cause if it's an older falcon you'll have to buy the RRS strut conversion and rack and pinion steering, and then scallop out the shock towers as the 5.4 BOSS is 250mm wider than a 351 cleveland. Any way, here is an a
#3 Posted : Monday, 23 August 2004 8:23:15 PM(UTC)
It's going into a xa coupe, have you done something similar. thinking of buying a front cut of an xr8 witht the boss in it so we get all the other bits like shocks and springs when we scallop the tower do you think we could use all the suspension out of
#4 Posted : Tuesday, 24 August 2004 4:02:55 AM(UTC)
I'm not sure if you could use the suspension and shockers from the Barra, and I'm also not sure where you will find a front cut of one. I was planing on the same thing for my XB ute, rang ford aus and tried to get a crate engine, searched the net, and end
#5 Posted : Tuesday, 28 September 2004 11:25:21 PM(UTC)
Try this place for a half cut
Ferntree Gully Auto Salvage
Rear 1152 Burwood Hwy
Ferntree Gully Vic 3156
Ph: 03 9758 6900
Fax: 03 9758 6899
