LOUY000 Offline
#1 Posted : Wednesday, 14 April 2010 9:52:43 PM(UTC)
LOUY000
How do you changeout the ignition barrel on a 76 HJ Statesman Deville,
I have bought a new set of locks and ignition but dont know how to do the ignition. I appreciate any help.
Thanks Louy000
Edited by user Wednesday, 14 April 2010 10:28:41 PM(UTC)  | Reason: Not specified
vanman Offline
#2 Posted : Thursday, 15 April 2010 7:28:19 AM(UTC)
vanman
For memory you need to remove the steering wheel and i think the indicator assy.
you should see a slot in the column casting midway along where the lock barrel is inserted..
insert a small sharp flat screwdriver into this slot.
put key in lock and turn to clockwise one click then pull out and barrel should release..
If it not one click clockwise try another position its been a while..
it should come out easily ..
good luck
Rhys Offline
#3 Posted : Thursday, 15 April 2010 8:48:24 AM(UTC)
Rhys
Also, if the ignition barrel has never been removed you will need to break through a paper thin casting with the screwdriver in order to create the slot. If you look carefully you will see in the light where the thin rectangular slot is.
LOUY000 Offline
#4 Posted : Saturday, 17 April 2010 2:18:16 AM(UTC)
LOUY000
Hey thanks fellars I will give it a go on the weekend, apreciate you advise.
