fellas ive just got hold off 2 utes and the floors are not the best what is the best way to fix them ie does any other floor fit them like sedan or wagon or do you reckon i just make 1 myself out off sheet metal big job i know but any help would be good thanks
kevy |
kevy |
Most of the floors are the same. Which floor do you mean? Front, rear etc?
its mainly from the beaver to the back wall in the cab its pretty messy but the rest off the ute is good so its worth saving thanks kevin
kevy |
kevy |
Ill have a look at a parts catalogue later, but from memory a lot of that rear floor is common with wagon, and even plenty of it is the same as sedan and coupe. Panel van will be the same too.
