ghg308 Offline
#1 Posted : Tuesday, 27 April 2010 3:46:18 AM(UTC)
ghg308
Did hk broughams ever have a holden six engine option?
as i picket one up the other day and it has the lower accelerator bracket near the heater box like a six cylinder?
#2 Posted : Tuesday, 27 April 2010 4:10:28 AM(UTC)
All the firewalls are the same, so V8 and 186S have screws in the holes, someone may have fitted a 186 at some stage after someone removed the 307.
Warren
CrustyHK Offline
#3 Posted : Tuesday, 27 April 2010 5:51:01 AM(UTC)
CrustyHK
All HK were 307 powerglide but most were ratted for the running gear then scrapped. A few survived by fitting sixes. I have a 186 HT Brougham sitting in Tassy which would have originally been a 307 as fitted to the early HT until they ran out of powerplants.
Keep in mind that the Broughams were about as popular as a fart in a space suit in the early days. Bit like the highly prized P76.
petaus Offline
#4 Posted : Tuesday, 27 April 2010 7:43:16 AM(UTC)
petaus
what was standard diff in the brougham banjo or ten bolt, i remember seeing a ht brougham with the hump in the tank floor?
pete.
#5 Posted : Tuesday, 27 April 2010 7:03:31 PM(UTC)
Crusty, all HT Brougham (except possibly a handful of REALLY early ones) were 308s not 307, with Powerglide. You can pick the difference between a 308 and 307 fitted HT by a few things.
Pete, all Brougham should be banjo.
castellan Offline
#6 Posted : Tuesday, 27 April 2010 9:20:33 PM(UTC)
castellan
I dont believe there were any HT broughams with 307 chev at all.
The 307 went into the other holden models.
The HT brougham used the 308 to boast its new 308 motor. also you could not get a 308 in any other holden until all the 307 chev motors were used up.
#7 Posted : Tuesday, 27 April 2010 9:55:50 PM(UTC)
There have been a couple of original HT 307 Broughams identified. Like a manual HT 307 a few snuck through.
petaus Offline
#8 Posted : Wednesday, 28 April 2010 2:18:21 AM(UTC)
petaus
i had nothing to drink the night before, it had the ten bolt diff and hump in the boot.
one off maybe?
#9 Posted : Wednesday, 28 April 2010 2:22:08 AM(UTC)
Probably
CrustyHK Offline
#10 Posted : Wednesday, 28 April 2010 8:52:28 AM(UTC)
CrustyHK
I better have another look at it next time I go over Byron. I did some quick research on it a few years back when I first picked it up and was sure it came up as a 307 powerglide. I never gave it too much thought as I read that they got rid of the last of the 307s in the first HT run.
#11 Posted : Wednesday, 28 April 2010 3:24:48 PM(UTC)
they did make 6cyl broughams aswell,my mate bought one,but we changed it to a chev v8.
since found out this must have been changed only v8 brougham so i was told
Edited by user Monday, 3 May 2010 3:42:14 AM(UTC)  | Reason: Not specified
#12 Posted : Wednesday, 28 April 2010 4:58:06 PM(UTC)
All Broughams were 5 litre. In HT you can tell between 307 and 308 in a Brougham or other car with factory power steering by the holes for the power steering cover under the drivers side subframe and also by the size of the threads for the accelerator cross shaft.
