Holdenon Offline
#1 Posted : Tuesday, 27 April 2010 8:14:23 AM(UTC)
Holdenon
I have Supra 5 speed behind a 253. It was supplied with a pretty crappy plastic flywheel cover (10 yrs ago). It has long since gone and I would like to replace it.
Two questions:
1. Can a normal Holden metal flywheel cover be adapted to fit.
2. Are the aftermarket Automatic flywheel covers for a Holden V8 the same as the manual gearbox ones?
thanks Scott
#2 Posted : Tuesday, 27 April 2010 8:27:36 AM(UTC)
nothing is available, one must be made from scratch
#3 Posted : Tuesday, 27 April 2010 4:28:23 PM(UTC)
It really depends who made the kit/bellhousing.
Ive had one where nothing fitted, and it required a lot of hacking of the metal cover to make it work, and others where the regular metal cover plate is re-used and simply bolts up.
The same metal cover plate is also used on commodore V8 trimatics, so theyre not hard to find.
Holdenon Offline
#4 Posted : Wednesday, 28 April 2010 1:20:20 AM(UTC)
Holdenon
Thanks guys, looks like Ill be doing the home modification job,
cheers Scott
